1 members (Snowman51), 94 guests, and 12 robots.
Topics128,014
Posts1,055,324
Members48,419
#1603042 05/03/2026 1:12 PM
1946 Chevy 261 with a 4 speed and a PTO mostly all original. Why does this not look right? I don't think the clutch spring should be like that, but don't know if I am missing a bracket. I still have to connect the brake spring to the bracket on the motor pan.
Hog Wild - Below is a screenshot from Bolter John "UtahYork" DITY Gallery thread for his '46 that shows his clutch release set up. Also included is a screenshot from the 1941 Truck Shop manual showing the arm and spring relation.
It look like you have a later clutch release arm that is missing the extended tab at the tip of the arm with the needed return spring anchor hole for retaining the spring on the arm. You could probably fabricate a small steel plate to get sandwiched between the adjusting and lock nuts on the pedal to arm piece to extend out to the side and hook the rear of the spring to.
Your return spring also looks too long. The Chevy Master Parts Book indicates the spring is GM# 368244 and should be 3-5/16" long and have 26 coils (see screenshot below from another thread).
Hope this might help. wink
~ Dan
1951 Chevy 3 window 3100
U
U Offline
Here was my final setup and I believe this is the factory setup - I hope. Using the same spring for both brake and clutch pedal returns. I'm with Dan - maybe you can fabricate a tab to hold the spring.
~ John in Utah
Here We Go
Follow in his DITY Bay
You can still find NOS GM# 368244 return springs for sale on line, as well as reproductions from many of our regular vendors like the Filing Station for a better price. wink
Below is a pic of the NOS spring from the ebay seller showing design and length.
~ Dan
Here's a couple of "clutch return spring tabs" pictures I found on line that might get the ideas rolling for helping fix your return spring anchor problem in line with my suggested solution above.
~ Dan
Thank you Gdads51 and UtahYork I think i found it in a bag of stuff. Lol. I have it on the lift now and going to make the swap.
U
U Offline
Great! Please post a pic after the swap. When I was working on mine, I had thought about what I'd do if the end of the clutch fork broke off. Maybe having a small spring tab in the tool bag might come in handy one day.
~ John in Utah
Here We Go
Glad to hear you found your goodies! thumbs_up
~ Dan
U
U Offline
The tab in your picture looked familiar and I believe it's for the starter return spring?
~ John in Utah
Here We Go
