6 members (TUTS 59, Keepinthemstockm, Wally / Montana, Jay R, papas52, 1 invisible), 94 guests, and 2 robots.
Topics128,084
Posts1,056,333
Members48,442
#1602898 05/01/2026 4:04 AM
Last year the hood on my '47 started popping open without warning. At first it was only occasionally, but then got more frequent. I knew the latch was cracked and slightly bent, so thought I'd tweak it a bit. Now it won't latch at all! I wired the hood closed when I put it away for the winter. Today I brought it home and messed with it a little more. No matter how I bend it, or which way, it refuses to latch at all. What did I do wrong?
I have a post in the swap meet looking for a different latch. If I don't find one, I'm guessing I'll have to get a new one, unless someone has any ideas.
Thanks!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
What does the post mounted to the hood that engages the latch look like?
1949/50 3600 Project
Follow in Project Journals
Rich - I'll second WICruisers note about showing us what your upper latch piece looks like. Your lower plate sure needs a replacement or repair, but the upper may have problems too to identify before being able to help you answer your question.
On the lower catch latch plate assembly, it's listed in both the 1954 and 1957 Chevy Master Parts Books as fitting 1947-53 Commercial and Utility Trucks (except COE's). See screenshots below. wink
So any 1947-53 Chevy or GMC truck (other than COE's) can be a donor to replace yours. I hope a fellow Bolter can help you out. Best of luck! thumbs_up *
* I posted this info in your Swap Meet ad in the hopes we can help you fix the problem. smile
~ Dan
1951 Chevy 3 window 3100
As near as I can tell, the upper post piece looks to be in good shape. I don't have it apart, and it's hidden inside the spring, so it's hard to see it. I did compress the spring as much as possible to get a look, and it looks good. I was able to loosen it and turn it about a third of a turn so that the latch would catch it in a different spot, but it made no difference.
Rich
1947 Loadmaster
Hammer the bent metal back to where it belongs and weld up the cracks and grind it smooth.
The latch pin in the hood is adjustable for length.
It needs to be adjusted until the nose of the hood slightly compresses the rubber bumpers in the upper radiator baffle.
