4 members (Gray_Ghost, 2-Ton, UtahYork, 55shaker), 72 guests, and 4 robots.
Topics128,187
Posts1,057,212
Members48,465
Good afternoon fellow Bolters. I have a 1953 Chevy 1/2 ton 3100 Panel Truck. I have a 235 engine from a 1954 Chevy Panel truck (blue flame) , I have the original rear end and torque tube, and I have the original 3 speed transmission with shifter on the column (3 on the tree).
I just bought a 1950 Chevy Panel Truck for parts only and I'd like to put the 4 speed transmission that came with it in my truck. I have my original rear end and torque tube and I have the rear end and torque tube and 4 speed transmission that came with the 1950 Chevy 1/2 ton panel truck. QUESTION - will the 4 speed transmission (1950) bolt up to my 235 engine (1954) and use whichever torque tube will join it all up , this should all bolt together, correct?
Another BIG QUESTION is - With the 4 speed transmission, I know that 1st gear would be granny low, then would 2nd, 3rd and 4th gears be like the 3 on the Tree gears? I know I have to put in the metal panel on the floor for the 4spd.
1953 Chevrolet 1/2 ton Panel Truck 3100
4800 LB. maximum rating, 85hp at 3300 RPM
6 Online: Content
Maybe this thread should be moved to the Driveline Forum?
Agreed and done.
Garageguy, to answer your questions. Yes, the transmissions and bellhousings will swap in without issue. The 4 speed and 3 speed torque tubes should be the same, the only difference would be the front yoke and bell on the rear of the 4 speed vs the 3 speed.
Gear ratios for the SM420
1st - 7.05:1
2nd - 3.58:1
3rd - 1.71:1
4th - 1.00:1
Rev - 7.05:1
Gear ratios for the 3-speed. (from 1951 Service Manual - apparently the later 53-54 heavy duty 3-speeds are slightly different)
1st - 2.94:1
2nd - 1.68:1
3rd - 1.00:1
Rev - 2.94:1
So it looks like your starting gear (2nd on the 4 speed,) would be a little lower than on the 3-speed, just meaning you should shift out of 2nd a little quicker than you would our of first with the 3-speed.
Reverse is also way lower on the 4-speed (so NO RACING in reverse wink )
