10 members (klhansen, papas52, baldeagle, 1955 1 Series, KEVINSKI, Hotrod Lincoln, TUTS 59, Gdads51, Dusty53, Lonnie), 178 guests, and 3 robots.
Topics128,165
Posts1,056,999
Members48,458
What are main and rod bearing journal diameters?
I don't have '54 302 specs. First attachment is from '52 GMC Maintenance Manual. Second is from '57.
'52
H Online: Content
248, 270, and 302 all run the same rod and main bearings, and journal diameters:
Connecting rods: Federal-Mogul #1905CP Standard diameter 2.3110-2.3120
Main bearing set #679M- - - -1954-55 engines
bearing #1: F-M #9846CP std. shaft diameter 2.6835-2.6845
bearing #2: F-M #9847CP std. shaft diameter 2.7145-2.7155
beating #3: F-M #9848CP std. shaft diameter 2.7455-2.7465 ( Flanged thrust bearing)
bearing#4: F-M #1909CP std. shaft diameter 2.7765-2.7775
Main bearing set #4030M- - - - -1956-63 engines
Same crankshaft dimensions as above.
#3 main bearing is F-M #1908CP No difference in the other bearings or dimensions.
Information from Federal-Mogul shop specifications book #115- - - -1982 edition.
Thanks fellas, appreciate it
