4 members (Wally / Montana, Gray_Ghost, Bucker, papas52), 82 guests, and 0 robots.
Topics128,163
Posts1,056,921
Members48,458
What are main and rod bearing journal diameters?
I don't have '54 302 specs. First attachment is from '52 GMC Maintenance Manual. Second is from '57.
'52
248, 270, and 302 all run the same rod and main bearings, and journal diameters:
Connecting rods: Federal-Mogul #1905CP Standard diameter 2.3110-2.3120
Main bearing set #679M- - - -1954-55 engines
bearing #1: F-M #9846CP std. shaft diameter 2.6835-2.6845
bearing #2: F-M #9847CP std. shaft diameter 2.7145-2.7155
beating #3: F-M #9848CP std. shaft diameter 2.7455-2.7465 ( Flanged thrust bearing)
bearing#4: F-M #1909CP std. shaft diameter 2.7765-2.7775
Main bearing set #4030M- - - - -1956-63 engines
Same crankshaft dimensions as above.
#3 main bearing is F-M #1908CP No difference in the other bearings or dimensions.
Information from Federal-Mogul shop specifications book #115- - - -1982 edition.
Thanks fellas, appreciate it
