5 members (PAUL Berardi, Bill Hanlon, Otto Skorzeny, moparguy, DaveV), 127 guests, and 1 robot.
Topics128,111
Posts1,056,244
Members48,437
1949 3100, 216, 6v Optima battery with alternator from Randy Rundle's shop many years ago. With engine at idle what voltage should I see at battery terminals and what would be the max as rpms increase?
Ed
O Online: Content
6.8v - 7.2v with engine running
6.3v - 6.4v with engine off
1950 Chevrolet 3100 (Ol' Roy)
B Online: Content
Don't be surprised if the voltage at idle isn't much (or any) above the engine off voltage. Our engines turn so slow at idle that an alternator just can't put out much power.
Any charging system- - - - -generator, alternator, or even a hamster running in a wheel, regardless of system voltage- - - - -will only produce enough voltage to push a charge into the battery. Against a very low battery, the charging voltage might only be 3/4 to 1 volt higher than the "engine off" voltage measured at the battery posts, but the charging AMPERAGE will be quite high. As the battery builds up a charge and its internal resistance rises, amps go down, and terminal voltage goes up.
You MUST know the state of charge of a battery before passing judgement on charging system voltage. Back in the dark ages when batteries had removable cell caps, we could stick a hydrometer in a battery cell, measure the specific gravity of the acid, and know for sure the state of charge of the battery. Now all we can do is check the open circuit voltage at the posts of a sealed-top battery and make an educated guesstimate about a battery's state of charge.
IF:
The battery is fully charged
The charging system and voltage regulator (internal or external) is functioning properly
AND
The engine is running at a fast idle speed or above and minimal accessories such as headlights, heater blower, etc. are turned off- - - - -
THEN
Battery terminal voltage should be around 7.5V on a 6 volt system OR 14.5V on a 12V system.
Under any other circumstances, you're making a SWAG ("Scientific Wild-Donkey Guess") at the very best!
Appreciate everyone's input! Ed
Ed
