1 members (Thomaslb),
138
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2026 Posts: 9 'Bolter | | 'Bolter Joined: Feb 2026 Posts: 9 | Many pardons if this question has been asked and answered before but my search hasn’t been successful in giving me the answer I’ve been looking for. I have a ‘54 3100 with the original 235 with a bypass oil filter. The block and filter are both 1/8” pipe thread. I was thinking of using copper tubing for the lines, same as the oil pressure gauge line that tees off of the same port in the block as the oil filter supply line. The oil pressure gauge line is 1/8” copper tubing but that seems small for filter lines. What is the minimum size for these lines? Thanks, Doug
| | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | I agree that the 1/8" tubing size would be too small for the oil filter connection. I believe that 1/4" tubing would work fine. I have some tubing that was used on the oil filter that was on my truck that I could measure for you.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | The filter standpipe has a 1/16" diameter flow control orfice in it, so even the 1/8" copper tubing that feeds the pressure gauge would flow enough volume. However, 3/16" or 1/4" OD copper/nickel hard line that most local parts stores sell in various lengths would be more durable and less likely to get damaged. It bends easily, with either a basic plier type tubing bender or just barehanded, if you're careful. Jerry
| | | | | Joined: Feb 2026 Posts: 9 'Bolter | | 'Bolter Joined: Feb 2026 Posts: 9 | Thanks guys, I think I’ll go with 1/4” brake line. That should take care of both size and durability. Doug | | |
