5 members (artinva, Opelika Tom, JW51, Gdads51, Otto Skorzeny), 65 guests, and 2 robots.
Topics128,077
Posts1,055,932
Members48,430
#1602526 04/24/2026 10:11 PM
I
I Offline
Many pardons if this question has been asked and answered before but my search hasn’t been successful in giving me the answer I’ve been looking for. I have a ‘54 3100 with the original 235 with a bypass oil filter. The block and filter are both 1/8” pipe thread. I was thinking of using copper tubing for the lines, same as the oil pressure gauge line that tees off of the same port in the block as the oil filter supply line. The oil pressure gauge line is 1/8” copper tubing but that seems small for filter lines. What is the minimum size for these lines?
Doug
I agree that the 1/8" tubing size would be too small for the oil filter connection. I believe that 1/4" tubing would work fine. I have some tubing that was used on the oil filter that was on my truck that I could measure for you.
The filter standpipe has a 1/16" diameter flow control orfice in it, so even the 1/8" copper tubing that feeds the pressure gauge would flow enough volume. However, 3/16" or 1/4" OD copper/nickel hard line that most local parts stores sell in various lengths would be more durable and less likely to get damaged. It bends easily, with either a basic plier type tubing bender or just barehanded, if you're careful.
I
I Offline
Thanks guys, I think I’ll go with 1/4” brake line. That should take care of both size and durability.
Doug
