4 members (NJC, Dusty53, 37 GC, Shade Baby), 137 guests, and 2 robots.
Topics128,141
Posts1,056,780
Members48,454
Dave’s current project.
Built in 1954 as a working truck. It has a sleeper cab made by
Orville metal specialty Co.
Powered by two GMC 302 six cylinder, which use two dual range hydramatic transmissions. One engine drives the rear diff, the other drives the front differential.
Two gas pedals, two sets of gauges…..
Does it need two drivers ?
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
Post pictures
1950 Chevrolet 3100 (Ol' Roy)
How does each set of driven wheels stay in sync with the other?
You sure it isn't a V12? GMC made a 702 cubic inch V12 in the early 60s that was basically two 351 cubic inch V6 engines hooked together in-line. They also had a Twin HydraMatic transmission that was one HM mounted right side up and another under it upside down, giving 7 speeds.
We Definitely need more info plus pictures!!
Another quality post.
Real Trucks Rattle
https://barnfinds.com/double-engine-monster-1954-assembled-vehicle/
This article, I’ve read before, sounds so similar, I wonder if it’s the same truck!
Dave will let us know, I’m sure.
~Charley
“Bud”
1954 GMC 3 ton 302
That's got to be the same truck. Dave is from British Columbia and the license plate on the truck is Washington state. Maybe Dave is the same Dave mentioned in the article.
I thought it might have been built for a mining company for off public hauling.
But, the color looks military. Maybe built specially for the Army?
Seems too wide for public roads maybe.
~Charley
“Bud”
1954 GMC 3 ton 302
