7 members (Gdads51, 55shaker, 1954gmc9314, carbking, J Lucas, dt235sd, 2-Ton),
52
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,022 Posts1,055,274 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Jerry: Why is a die adjustable? When you're threading a piece of blank round stock, the die is expanded a few thousandths to make a rough cut, then tightened up a little at a time to sneak up on the final pitch diameter and smooth out the cut. Trying to do a full thread in one pass usually results in a crooked thread, or one that's undersized and rough. Dies that are intended for repeatedly threading solid round stock are VERY adjustable, but they require the use of a special die stock to allow for the adjustment as a finish thread is completed. www.ebay.com/itm/363989272119?Jerry
