3 members (Peggy M, TUTS 59, Maybellene), 175 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#1601953 04/16/2026 2:09 PM
I am restoring a 1953 Chevy 3100 1/2 ton truck. It has a Chevy 3-speed manual transmission. I have rebuilt the transmission, but I seem to be missing a seal that goes on the front of the trans under the bearing retainer. This would keep transmission oil from coming through the input shaft bearing. I have checked all of the usual sources but can't seem to locate this seal. This is not the gasket, I have that. This is a seal that goes around the main input shaft. Anyone know where I can get one of these?
They didn't come with a seal.
The front bearing retaining nut is also intended to be an oil slinger for oil to be returned
back into the case. In addition the inside of the front bearing retainer (the part the
throughout bearing rides on) is machined to correspond with the slinger.
If there is excessive wear on either or both of these parts, oil can leak out.
The slinger/nut is left hand thread and some times are removed or installed with
channel lock pliers which damages the part.
Fred
AD Addict & Tinkerer
Be sure to position the bearing housing so the half moon opening is on the bottom, so the oil will drain back into the tranny casing.
The bearing lock nut takes a special wrench which I fabricated from 1/8” flat plate. Here is the post that shows the wrench.
Phil
Project Journals
Stovebolt Gallery Forum
As long as the transmission isn't overfilled with oil, and/or the vehicle isn't parked on an extreme downhill angle, there won't be any leakage into the bell housing. Later transmissions such as the Saginaw 3 and 4 speeds did have a front seal, but the SM 318, 319 3 speeds, and most SM420 4 speeds didn't have one.
Thanks to all. I did not remember removing a seal when I took this thing apart, but when reassembling, it seemed like there should be a seal there. Guess not.
Thanks again.
