4 members (TUTS 59, jmoore, 66flea, Ponchogl), 113 guests, and 3 robots.
Topics128,127
Posts1,056,681
Members48,452
Just picked up my starter motor from the repair shop. They went through it cleaning and replacing some components. I mentioned bringing in the old generator to have them check it out. The shop owner told me if anything had to be done on it the repair bill could run as much as $400 easily. Said if I didn't care about straying from all original it would be far better to purchase an alternator and ditch the old generator and voltage regulator. I was thinking that direction in any case. This is on the 1956 3100 I'm restoring.
Your thoughts, one way or another?
Alternator is what did on my 2 old trucks. They are drivers. 3 wire works better than 1 wire and not that much harder to install.
Insomniac
Insomniac
I have a 63 amp 10SI alternator installed and I am happy with it. This is a three wire alternator. The sense wire runs to the accessory side of the ignition switch. If you run it to the ignition, the engine will not shut off. Plenty of posts on this forum on how to do it.
e.g.
10SI alternator
To install, I swapped the generator bracket end to end and drilled a new hole to match the mounting points on the block. This made the alternator pulley line up with the water pump pulley.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Putting an "idiot light" in series between the sensor terminal and the ignition switch will prevent feedback to the ignition system and avoid the run-on problem on shutdown. Use a regular 2-wire incandescent indicator bulb, not an LED. The bulb filament limits the current backflow so there's not enough to power the ignition system.
www.ebay.com/itm/115585726046?
24601
If *looking" original is still desired, I seem to recall at least one vendor who sells an alternator that looks like the original generator....
I just looked one up (Powermaster) while I was writing this .... ouch. They want close to $600 for it. Nevermind .... frown
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Moderator, Electrical Bay
Welcome to the site. I have a one wire 100 amp. Installed it a few years ago and have had very good luck...much better than a generator. If you're installing an AC and electric radiator fan or fans, you will definitely need an alternator. I haven't spent a summer in San Angelo since the mid 60s but as I recall, July can be pretty hot.
~ Jon
Yeah, those are cool but not at that price.
You buy an all-black 10si alternator without spending a ton of money. Although it won’t fool anyone who’s looking closely, I do think a black one draws less attention and looks less out of place on an old engine.
That’s kinda/sorta the plan for my truck when I get around to it. Generator just keeps working so it never makes the top of the list.
Alongside that, also have a half-baked idea on gutting a voltage regulator and using it to hide some junctions and fuses.
1951 3100
O Online: Content
If I was faced with spending that kind of dough, I'd switch to an AC generator as well. As it is, All of my vehicles with dc generators just keep working. The one in the Cadillac was rebuilt about 5 years ago along with Ol'Roy's. Those rebuilds/repairs cost about $100 each.
1950 Chevrolet 3100 (Ol' Roy)
Very hot, but dry hot in the summer.
As always, thank you for your input, fellow stovebolters (smiley face goes here).
Powermaster also doubles as a vacuum cleaner- - - - - -it sucks money right out of your pocket!
Lot of vacuum cleaners out there, for sure.
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
I changed my '58 4400 to an alternator. It was one of the best modifications I have done as Bang for the Buck. I purchased a internally regulated AC Delco reman from RockAuto or less than $80.00. The internally regulated alternator eliminates the firewall mounted regulator.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
