7 members (Guitplayer, JW51, mo2cyl, Otto Skorzeny, 55shaker, Wally / Montana, 1 invisible),
73
Mod | | | Forums66 Topics128,050 Posts1,055,757 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2023 Posts: 25 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 25 | I have a dumb question. Considering putting a T5 in my 1954 3100, naturally need to convert to open driveline. Is it possible to use my current rearend housing, but install the "pumpkin" from a later 50s Chevy? My goal is to keep my 6 lug wheels. Thanks. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | A third member out of a 1955 through 1962 Chev or GMC 1/2 ton will bolt into your housing. The torque tube was used as a torque arm and the axle housing is hinged at the springs. You will have to change spring seats, weld what you have tight or add a torque arm. | | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | A third member out of a 1955 through 1962 Chev or GMC 1/2 ton will bolt into your housing. The torque tube was used as a torque arm and the axle housing is hinged at the springs. You will have to change spring seats, weld what you have tight or add a torque arm. This is exactly what I did when installing my T5. We cut off the pivoting spring seats and welded on some solid spring seats from Classic Parts (~$20). The 3.90 ratio works well with my T5 and tire setup. | | | | | Joined: Mar 2014 Posts: 4,482 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,482 | If you can find a 12 bolt rear out of a late 60s/early 70s Chevy pickup these are the right width and can be made to work with the AD springs without too much work. Plus you will get a large variety of gear ratios in the 12 bolts. I have a 3.07 and with the ratios in my T5 it works really well. The first 3 gears almost exactly the overall ratios GM engineers used with the 1/2 ton trucks and inline sixes and then 4th drops the rpms by 25% and fifth (.86) drops that another 14 percent which puts me just a little better than an overdrive 3 speed would have provided. The 12 bolt rear ends used in Chevy pickups (maybe also in GMC) were made for 6 lug wheels.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
