3 members (WICruiser, baldeagle, Peggy M), 214 guests, and 5 robots.
Topics128,106
Posts1,056,214
Members48,436
#1601240 04/05/2026 9:29 PM
What kind of spacing between the cab corner and the filler panel that goes between the box and the running board mine were cut to put exhaust stacks and the repo one I have seems to be a tight fit .54 model truck
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
My repop panels weren't a great fit either. I had to stack some washers on the top bolt to get it to bolt up. The 54-55.1 aprons are different than the earlier 47-53 ones. Are you sure you got the correct aprons?
Yes they are the right ones ,origional and I picked up a new repop one to see how it fits but we’re it curves by the cab it is almost touching and the curve on the repop one is off. The problem is that curve was mostly torched out to allow the exhaust stacks that were on it when I got it so the ones that are from the truck were patched so I don’t know what type of space should be between the cab and the panel .
"The Journey"
Follow in the DITY
I'm thinking about 1/4 inch should be right. Can't confirm that right now. But the cab has to move a bit relative to the frame.
Thanks I will give that a try .
"The Journey"
Follow in the DITY
Professional procrastinator
Here is a couple of shots from original trucks
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
