0 members (),
132
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 313 | Hello, All,
I have owned Stovebolts for 35 years, but have never had this happen. After a short drive and back home, I am noticing there is very little play in my brake pedal, in other words, the pedal is almost all the way up to the top, and has very little travel before brakes are applied.
I just recently installed all new brake shoes, drums, and wheel cylinders and none of the brakes are too tight, because I just got back from a drive, and felt all 4 wheels and none are warm. I am wondering if my master cylinder is going bad. It's the only thing I haven't replaced.
1953 3100
TIA
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
| | | | | Joined: May 2015 Posts: 11,278 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,278 | Before you condemn the master cylinder, adjust the pedal linkage so that when you look in the reservoir, you see a little spurt of brake fluid. That means the relief port is not blocked. If you don't see that spurt, that means the port is blocked and expanding brake fluid (from heat) has nowhere to go.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2004 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 313 | Before you condemn the master cylinder, adjust the pedal linkage so that when you look in the reservoir, you see a little spurt of brake fluid. That means the relief port is not blocked. If you don't see that spurt, that means the port is blocked and expanding brake fluid (from heat) has nowhere to go. Thanks, I will check that out. It's possible that a piece of rust could be blocking the port. I just went out and check, while pumping the pedal and there is no spurt in the MC, at all, and the bottom of the MC is rusty looking.
| | | | | Joined: Oct 2021 Posts: 7,039 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 7,039 | I think you've answered your question.
You can rebuild your original, send it off to have it rebuilt, or buy a new one for about $40.
I bought a Dynamic Friction brand mc from rock Auto a few years ago and it's working just fine.
If you buy a new one, save your original to rebuild in the future.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Mar 2004 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 313 | I think you've answered your question.
If you buy a new one, save your original to rebuild in the future. Hey, Otto, How are you? Yeah, after Kevin explained things, it made sense to what was happening. I will look at Rock Auto, I buy a lot of parts from them. Thanks! Kevin
| | | | | Joined: Dec 2024 Posts: 114 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 114 | Several of the vintage truck suppliers (Filling Station, Jim Carter, etc..) sell the master cylinder rebuild kits. Pretty simple to rebuild them.
Geoff
1955 2nd Series 3600 235 cid, 4 sp. - Current 1979 Chevy K10 350 cid 4 sp -Sold 1955 2nd Series Wide Window 283 cid 3 sp - Totaled
