2 members (1955 1 Series, UtahYork), 77 guests, and 4 robots.
Topics128,189
Posts1,057,222
Members48,465
#1600476 03/25/2026 3:22 AM
Does anyone know where I can find an exploded view of steering column and horn button assembly for a '53? My apologies, I still haven't figured out how to access things from the archives. Thanks.
FAM Section 9, Sheet 1.00 shows that.
Kevin's diagram from the FAM is a 1954 specific steering wheel setup. There are a few differences between it and your '53 as yours will have the upper steering column bearing/horn contact piece and a different looking wheel and horn button & contact ring.
Here's a picture from a 1953 Chevy Master Parts Book showing the typical truck steering wheel parts exploded diagram. Please note it is not a 100% match to your '53 as it shows an earlier 1941-46 setup. The retainer, bumper and spring shown don't go with your '53.
A closer approximation of what your '53 has can be seen if you look at the below LMC catalog diagram. Yours will include items 1 (steering wheel), 11 (upper steering column bearing and horn contact), 14 (spring loaded horn contact button), 15 (horn button contact cup), 17 (steering wheel to shaft nut - yes there should be a washer in there), and 18 (horn button).
Maybe a little less muddy? headscratch
~ Dan
1951 Chevy 3 window 3100
Thanks Dan, exactly what I needed to see.
Moderated by  ndkid275, Phak1
