0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
1950 3100 original trans, clutch etc.
First thing first
When in 1st gear it pops out before I can shift into escond gear
2nd question
Grinds when trying to put in gear, this is a 3 on the tree.
Any suggestions on what is wrong and how to fix?
Jim
1950 chevy shortbed 3100, 216 with a 3 on the tree.
First thing to check would adjustment of the shift linkage. Also, the clutch adjustment could need checking. Does it grind in all gears or just first?
Grinds when trying to put in gear, doesn't matter if it's 1st or reverse, from dead start, not rolling.
When driving it pops out of1st gear before I shift into 2nd gear. Can it possibly be the shifter detent spring, if so is there a place to get one along with a side cover gasket.
Just got some information from old parts guy. He said to put in first gear. Disconnect the linkage rod and push down and see if it goes down farther if it does then its a adjustment issue. He also stated it it pops out of 3rd gear its a imput shaft issue.
Your opinion?
Yes, popping out of 3rd is either worn input shaft clutch teeth or the synchronizer ring. Grinding from a dead stop going into gear is a clutch issue - not releasing all the way. Could possibly be that the disk is binding on the input shaft splines, or a bad pilot bushing. Or possibly too much free play before the clutch pedal feels harder. That's an adjustment thing. There's info on adjusting the shift linkages in the service manual. Start here and read the next few pages.
if you can't fix your transmission, PM me. I have two or three 3 speed transmissions to choose from. I am eager to get them off my floor.
Most of my toes are stubbed.
Carl,
Hey are the transmissions good or do they need rebuilding?
Jim
