| | | Forums66 Topics128,052 Posts1,055,725 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2026 Posts: 70 'Bolter | | 'Bolter Joined: Mar 2026 Posts: 70 | Anybody had dealings with this company, good or bad? | | | | | Joined: Mar 2007 Posts: 3,383 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,383 | They were started be one of the lead engineers from Arias Pistons. I haven't used any of their products but they seem to be strong with the import guys..
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Mar 2026 Posts: 70 'Bolter | | 'Bolter Joined: Mar 2026 Posts: 70 | | | | | | Joined: Aug 2010 Posts: 600 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 600 | Looks like they only sell for imports, and the prices always seem to start at $750.. *per slug.* Yes, that's $3000 for new pistons in your B20. So yes, I would assume they could make you whatever you want as they claim to offer the service.. but I think they might be a little bit overpriced for what we're building around here. :-O
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Egge Machine will make oddball pistons, but they must be making them of Unobtanium- - - - -your checkbook will need CPR before you get anything made by Egge! It's so simple to grab a specification book and find a suitable substitute for most internal engine parts, that I can't imagine why anyone would subject themselves to the price gouging the resto-ripoff places try to charge for "custom made" parts! Jerry
| | | | | Joined: May 2015 Posts: 11,034 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,034 | I paid less than $400 for a set of 6 pistons from Egge that I used to install a 235 crank and rods in my 216. They even fitted the pins from my pistons in them. I was pretty satisfied with their response. But you're probably correct about custom pistons being EXXXXPENSIVE. I also talked with Ross Pistons, and they'd do custom pistons for around $1300 for a set of 6, IIRC. I passed on that, of course.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | I use my Silv-O-Lite (paper) catalog frequently. It has a very extensive listing of piston applications, with detailed dimensions such as bore diameter, available oversizes, compression height, piston pin dimensions, etc. Most applications also include standard and metric dimensions. Ditto for the Federal Mogul #115 shop specifications manual, for bore, stroke, crankshaft dimensions, and a lot of other internal engine measurements. Add a calculator and some math skills and the sky is the limit! The AERA (Automotive Engine Rebuilders' Association) publishes a series of shop manuals for connecting rod, cylinder head, and engine block specifications. Used editions of most of those manuals are available for purchase on Ebay pretty frequently. Jerry
| | | | | Joined: Mar 2026 Posts: 70 'Bolter | | 'Bolter Joined: Mar 2026 Posts: 70 | Egge got back to me, finally , said these piston must be made from forged blanks, which they don’t offer. Said I should get in touch with Traum. So far no response. Ross pistons will supply pistons any size I want. Going to sleeve the two worst cylinders first, see how they turn out before order pistons. | | | | | Joined: Mar 2026 Posts: 70 'Bolter | | 'Bolter Joined: Mar 2026 Posts: 70 | Thanks, will check it out | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | I think Kris says it better than I ever could! www.youtube.com/watch?v=faF0wOsVucwI give up! Jerry
| | | | | Joined: Jul 2018 Posts: 267 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 267 | R I P , Kris . Well Said. 🥲
~Charley 1954 Chevy 3100 with 235“Bud”Follow along in the DITY1963 Chevy half ton stepside short box 230 1954 GMC 3 ton 302 And several more Chevy camper and work trucks 1979 1987 1996 | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | The Pistons Don't Care What Kind Of Engine They're In!
There are at least two dozen engines that run a 4 inch piston!
MAKE THEM FIT! Jerry
| | | | | Joined: Mar 2026 Posts: 70 'Bolter | | 'Bolter Joined: Mar 2026 Posts: 70 | Thanks for the Silv-O-lite link, pretty informative. I guess the issue with these 4.0” dia pistons for the early GMC 302 is finding one that has the compression height of 2.375”
Dave | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Changing the stroke and/or the rod length makes compression height much less of an issue. Decking the block a little is also a possibility. Tall deck Diesel pistons with 1/2" thick crowns can be machined down if they're too tall. Having a few brain cells to rub together opens up all sorts of possibilities. At one time, Chevrolet parts departments sold a "semi-finished" connecting rod for 350 V8s with no wrist pin hole and a small end area over an inch tall. Custom engine builders could decide how long they wanted the rods to be and finish-machine the rods to the desired length. That was very useful for oddball bore/stroke combinations. Outsmarting tech inspectors at the circle tracks where we ran was almost as much fun as winning races. Jerry
