2 members (55shaker, Peggy M),
78
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2026 Posts: 15 'Bolter | | 'Bolter Joined: Mar 2026 Posts: 15 | Is a complete wiring harness/loom available for '47-'53 trucks? My original wiring is intact and working, but is in bad shape. I was going replace the wires one at a time, but a complete set would be better. | | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | Here are a couple companies that will make a new harness for you. It would be a lot cheaper to do it yourself one wire at a time as you said. There can't be more than 8 or 9 circuits on that truck. Complete reproduction wiring harness for all makes and models YNZ Yesterday's Parts http://www.ynzyesterdaysparts.com/909-798-1498 Wiring harnesses for all years, all makes and models Rhode Island Wiring Service, Inc. 567 Liberty Lane, PO Box 434 West Kingston, RI 02892 (401) 789-1955 http://www.riwire.com/
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Sep 2009 Posts: 5,837 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,837 | Wes - Are you looking for a restoration "original" style wiring harness, or just a replacement for functionality? In a bare bones response, yes there are lots of different replacement wiring harnesses/options pre-made for your '48.
Take a bit and consider what exactly you want as an end result, original reproduction, original style new modern materials with no changes, original style with some modern upgrades (like converting to 12v and an alternator), addition of turn signals, radio, etc.
Provide more definition to what your goal is and folks can offer better pointers towards sources that we know are reliable and as wallet friendly as they can be.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | What I did on my '51 was to replace deteriorated sections of the harness with original braided wrap wire. The splices I did were hidden beneath the vinyl wrap I used on the entire harness. While i was at it, I added wires to the front parking lights for turn signal circuits. It didn't take that long to repair the harness, but the vinyl wrapping was a two-person job. I posted some write-ups and pics in my Project Journal, starting with this post.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
