Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Otto Skorzeny, carbking, tclederman), 152 guests, and 4 robots.
Topics128,284
Posts1,058,526
Members48,490
Page 1 of 2 1 2
Donald S.
Donald S.
Well, since I am now officially retired, I am taking on my next project.
I restored my 1953 5 window very close to original except a nice paint job and nice rims. The wife and I have very much enjoyed it going to fund raising car shows and the big one in south MS, Cruisin' the Coast. So this will be for her to take since she really enjoys going, too.
The one minute summary: it will be a '49 Suburban on a 1998 S10 frame keeping the 4.3 V6 rebuilt engine, updated interior, AC, PS, PB and a few other updates. Depending on the final stance on the s10 frame, I may lower it just a bit.
I purchased the vehicle from a fellow Stovebolter in Crystal River Florida -- 7.5 hr drive one way. Me and a couple guys drove down and I rented a large U-Haul to put all the pieces he had taken apart. Spent the night along the way back and made it back the next day.
The first picture (below) is how the previous owner got it on the trailer. The second picture is how I brought it back to MS still attached to a rotisserie.
Overall it looks pretty good and he had already done some body work in the usual rusted places.
More to come! 🚙
First before picture
Second before picture
Cropped for embedding by editor
1949 Chevy Carry All
Follow the resto in the Project Journals
1953 Chevy 5-window
"Frame off Restoration"
Follow the resto in the DITY
Beginning to End Slideshow
More images in Flickr
\|/\|/ Dual Ex. \|/\|/Dynamat
Please don't tell my wife how much this thing cost!
Sounds like a great project and what a find as a starting point (the rotisserie is a great bonus).
1949/50 3600 Project
Follow in Project Journals
Donald S.
Donald S.
Yes WICruiser, the previous owner included several other items. A MiG welder, table top sandblaster a portable sandblaster a chop saw and ALOT of already purchased new parts for some I need and some I will sell.
1953 Chevy 5-window
Former Workshop Owner
Looks to be in great shape. Good score.👍 Thank you for posting the pics.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Bondo Artiste
Bondo Artiste
Gotta love a rare Burby! Nice score!
~ Phillip
Glad to see the Burb found a new Stovebolter home. thumbs_up Looks like it was very much original and complete when the original Stovebolter brought it home. Is the Mrs taking a hands on approach to her truck, or just consulting/directing the project? grin
It would be interesting to know who the Stovebolter who previously owned it is, if they don't mind folks knowing. wink Kinda helps know and document the history of the truck in our community.
~ Dan
1951 Chevy 3 window 3100
Donald S.
Donald S.
Gdads51, I think she will but you never know sometimes. Definitely at least consulting 🤣😂. I don’t think the PO would care, it was Oldngray
1953 Chevy 5-window
Donald S.
Donald S.
So I jumped pretty quick onto the frame after removing all the S10 parts. I cut all the S10 mounts off and ground everything smooth. I am using the Henry Panza kit for mounting the 49-53 short bed trucks. The burb is different after the 4 cab mounts. But it will not be a problem. The frame even though it was 1998 was not very rusty but after I mounted the Panza kit, I pulled all of them off and sanded and wire brushed the whole frame everywhere that was accessible. The front 2/3 of the frame is boxed so cleaning that inside was impossible, that area inside I used Eastwood rust encapsulator, they have pretty neat 2’ long spray nozzle that makes it pretty easy to coat. I used a borescope camera that hooks to my phone to check out the inside. After a couple of coats I probably have about 95% coverage. I used their same product on the exterior of the frame. Once that was completed I had previously had good experience with Martin Senor chassis black. You can touch up or partial recover an area and cannot see a dividing line. It is discontinued but replaced with an “all purpose” black. Seems like the same paint to me. Once that was completed I put all the Burb mounts back on after painting them with the same black. With the frame done except for the rear end (more later). I am using the 4.3 with a carburetor and decided to not use the fuel pump in the tank. I changed the tank and pickup to use an electric fuel pump and will mount it on the frame. I will redo the fuel line and return later. After changing the fuel tank I had to modify the radiator support using the info in the Henry Panza kit. The Panza kit is pretty nice, he has worked out all the geometry for assembling the parts. All the way to the inner fenders that will need to be notched. No welding required it all bolts on with grade 8 bolts and heavy brackets. More soon!
Rear frame
Overall frame
Gas tank
Radiator mount
Rusty frame
1953 Chevy 5-window
Thanks for the info Donald. I found "Oldngray" only had one active post back in early February of 2025 that left some hints about the truck and where it was at back then. Guessing he may have posted in the Swap meet back then, which would be long gone now even though the post count is still included.
Sounds like from his post he had already done much of the mechanical work with notes about engine rebuilt, trans and rearend already done on the chassis? Or was that on the original chassis and driveline stuff (pre-S10 chassis)?
One other thing he mentioned that caught my eye. He said its a "49 Clamshell carryall". I kinda thought that might be the case, seeing the first pic you posted, but couldn't tell for sure from the across the back side view.
Looking forward to following your new project. smile
~ Dan
Donald S.
Donald S.
Yep, he had done a lot on the original chassis and body some of which I will not be using. He and I did PM a good bit to work out the details. Yes it is a clamshell carryall. I am looking forward to this new challenge.
1953 Chevy 5-window
Authorized Pest
Authorized Pest
This looks like another adventure (your '53 half-ton) in the making. I bet the Panel & Burbs fellas will be following this.
Keep us posted.
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
Donald S.
Donald S.
Ok so here are some “before” pictures before I start my body work. The po did some repairs and some priming. I will be reworking some of it and continuing deeper where I feel the need to. I need to focus on the double wall areas from the doors to the back and door and window posts. I had my 53 dipped to kill the rust than EDP coated for the double wall in the back and the door posts but am not taking that approach this time. Please chime in on what you did and how comfortable you were with the results in this situation would be appreciated? I don’t want to reinvent the wheel. Right now I am just thinking doing the same as the frame using Eastwood Rust Encapsulator. I saw a video of it and like products on rusty metal in the yard on the ground for a year or two and it seemed as good as anything.
“Cab Before”
“Cab Before”
“Cab Before”
“Cab Before”
1953 Chevy 5-window
U
U Online: Content
Looks like a lot of space in there. Who needs a truck! 😉
~ John in Utah
Here We Go
Follow in his DITY Bay
Donald S.
Donald S.
UtahYork, yep the back is going to have updated seating to accommodate the wife driving and others including the 2 grand babies. I have to make sure the passenger seat hinges up for access to a couple more seats and probably a bench seat at the rear.
1953 Chevy 5-window
AD Addict & Tinkerer
I’m delighted to invite you all to join me in extending a hearty Stovebolt welcome to Donald S., better known on the forum as SouthernTruck, as our lastest contributor to the Project Journal forum.
Many of you may already be familiar with Donald’s impressive work. He recently completed a stunning frame‑off restoration of a 1953 Chevy Five Window —a masterpiece that still turns heads in our Completed Journals section. If you haven’t yet taken a moment to admire his meticulous craftsmanship, I highly recommend a visit; it’s a true testament to the dedication and skill that define our community.
Donald’s passion for classic trucks continues to evolve. His latest project is a heartfelt build for his wife—a 1949 Chevrolet Suburban, transplanted onto a 1998 S‑10 frame. The build will retain the original 4.3‑L V6 (fully rebuilt), and a refreshed interior, modern air‑conditioning, power steering, power brakes, and several other thoughtful upgrades. It’s being prepared for fundraising car shows, where it will not only look spectacular but also serve a great cause.
Please join me in welcoming Donald to the Project Journal forum. His experience, enthusiasm, and generosity in sharing progress updates will undoubtedly enrich our discussions and inspire fellow members.
Welcome aboard, Donald! We’re thrilled to have you with us and can’t wait to follow every step of this exciting new journey.
Warm regards,
Phil
Moderator– Project Journal Forum
Phil
Project Journals
Stovebolt Gallery Forum
Donald S.
Donald S.
Finally getting started on the body checking what to cut out and or replace. Went thru all the holes on the firewall which ones I probably will use and the ones I won’t will get welded up. Once I rotated the body to get to the bottom, overall it looks pretty good. I have to rework some patches that were held on with aluminum rivets. That’s not going to work for me. Drilled those rivets out and plug welded the panel on. The front floor repair is also getting redone as the new metal is overlapped and welded with the existing and that’s not good enough either. I had to cut thru and follow the weld to bring it back to a flush welded seam. The wood floor looks good and had been preserved well by the PO. Once I get all the lower sheet metal work done I plan to undercoat everything. Be back soon!
Firewall holes
Suburban bottom
1953 Chevy 5-window
Is that like a 5 million ton capacity body rotisserie? I mean, cause the Suburban body comes in at about 5 million and 1, no?
Donald S.
Donald S.
MNSmith, man I don’t know. I bought the burb with it attached. I’m guessing that body weights about 1k. What you think?
1953 Chevy 5-window
I shoulda weighed mine when I had the chance!
Donald S.
Donald S.
Nice picture!!
1953 Chevy 5-window
Donald S.
Donald S.
Not much exciting info 😂🤣. Just cutting out the bad metal and replacing. Plugged about 40 holes in the firewall that I won’t be utilizing this go round. I also removed the drivers seat riser so I could have a consistent floor all the way across. Removing all the under the wood floor braces to clean them up and paint with rust killer also replacing all the fasteners that are pretty rusty. I will add pictures as soon as I can figure out how to get my phone to keep them under 5 mb.
Wood floor rework
1953 Chevy 5-window
Before I found an app, I would email the photos to myself and it would reduce the size automatically.
Now I use an app called Photo Reducer on my iPhone. There are simular apps for android platforms.
Phil
Project Journals
Donald S.
Donald S.
Yep, I need to try the app. Thanks for the info, sometimes I can crop them and get them down under 5mb
Your emails suggestion worked easiest. Gave me several options for size.
1953 Chevy 5-window
Donald S.
Donald S.
Still cutting and replacing rusted metal. The drivers door sill had a good bit of rust but it was only about 2” from the the bottom so I just cut and replaced the bottom 2” of the whole thing. I have more fasteners to replace but need a deeper cutting wheel to reach inside of the channels under the floor. I am also wire brushing under each fastener before replacement and coating with rust encapsulator. I also removed the seat floor mount brackets plugged those holes with a dowel rod and wood glue. I will have to use wood filler inside on the floor since these were recessed.
Door sill repaired
Fastener replacement
1953 Chevy 5-window
Crusty Old Sarge
Crusty Old Sarge
Donald, It's great to watch your progress on the Burb.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Donald S.
Donald S.
Slow but sure. 😂🤣
1953 Chevy 5-window
Donald S.
Donald S.
Working on the drivers side outer cowl. Replacing the bottom 6” or so because too rusty. The PO drilled a row of holes up the center to repair an inward dent. Got that whole area pulled out flush and welded his holes up. I am doing away with the drivers side vent so filled that in and welded that up.
Drivers side vent door
1953 Chevy 5-window
Donald S.
Donald S.
Cut out and replaced the bottom of the drivers side cowl. While I had it cut out coated everything I could get to inside with rust encapsulator.
Drivers Cowl bottom
1953 Chevy 5-window
Donald S.
Donald S.
I haven’t put any time into my Suburban project in the last 5 weeks. We have been to Texas and California both but are home now so I should get back on it after the 4th. Family time!! Stay tuned.
1953 Chevy 5-window
Donald S.
Donald S.
I’m still here, finally got back to cutting and welding patches. I ended up ordering the bottom patch panel between the door and the rear fender on the drivers side. I originally tried to just patch the original but it was too bad. I don’t have the picture of it but will get one. The PO did the other side and then added bondo. Yesterday I wire brushed all the bondo off and didn’t like what I had so I redid it too. I also patched the vent up by the windshield and got it all welded up. The wife will have A /C only so I decided to do away with it. The only things have left to do on the body is replace both inner cowls, (already have the new ones)and weld up the outside fuel fill opening since the S-10 is on the other side. Then I will move on to treating the inside double wall areas of the body with the rust encapsulator. Then come doors and fenders. They don’t seem to be bad but stay tuned. I will try to get more pictures.
Upper vent
Welded upper vent
1953 Chevy 5-window
U
U Online: Content
I'm sad to see the cowl vent disappear. 😥
~ John in Utah
Here We Go
Donald S.
Donald S.
UtahYork, if it’s any consolation, I left it on my 53 truck! 🤣😂🤣
1953 Chevy 5-window
You’re making good progress and great looking work!
Phil
Project Journals
Donald S.
Donald S.
Worked yesterday on the PS inner cowl. I did not replace the whole cowl but cut along the inside radius of the inner and outer cowl part. This allowed me to clean and treat the rust on the inside flange before replacing the inner cowl. Both inner cowls were rusted thru along the flange. Next comes the DS inner cowl.
Passenger side inner cowl replaced
Drivers side not done.
1953 Chevy 5-window
If your inner-to-outer cowl pieces were intact, you're doing good. Mine were completely rusted away. I was able to pull the front clip without removing any bolts where the fenders attach to the cowl.
Keep up the good work. thumbs_up
Donald S.
Donald S.
Kevin, yes they were in surprisingly good shape.
1953 Chevy 5-window
Donald S.
Donald S.
Got the fuel filler hole tacked in on the passenger side. Welded and ground the inner cowl. While I was there I decided to close up the floor battery opening. The battery will either be in a drop down type box or I will mount it under the hood. The S-10 frame goes right thru the battery area. So tomorrow will be the drivers side inner cowl.
Fuel filler opening
Floor battery opening
1953 Chevy 5-window
Donald S.
Donald S.
I also started purchasing items that will be used on the finished Burb. I am using Aultman door latches. I have to make sure the wife doesn’t fall out( even though I have never had an issue on my 53). New brake booster and master cylinder and power windows.
1953 Chevy 5-window
You'll love the Altman latches. Mine are great. Only downside is you lose the ability to lock the door from the inside.
Donald S.
Donald S.
Bill, so you only can lock from the outside? How about the passenger door?
1953 Chevy 5-window
Page 1 of 2 1 2
Moderated by  Phak1
