| | | Forums66 Topics128,111 Posts1,056,258 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2023 Posts: 45 'Bolter | | 'Bolter Joined: Sep 2023 Posts: 45 | After cleaning out the scale from inside a long dormant original gas tank what would you recommend to neutralize any rust inside the tank? I’ve used Ospho before for treating rust on exterior applications and was hesitant to do so because of the scale that remains after the Ospho dries. Thanks in advance. | | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | Bill Hirsch LINK sells what they're calling "Gas Tank Etch" which says it leaves a gray phosphate coating, so is probably just the same as Ospho. They also sell gas tank sealer. If it was me, I'd just replace the tank, unless it's not readily available.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 4,482 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,482 | A tank for a 55 1st series is readily available from many vendors. I bought a Spectra tank made in Canada for my ‘52 , and it fit perfectly. Prices have gone up considerably since I bought it two years ago. Currently many vendors have it for less than $300. You can find cheaper tanks, but there are horror story's about them not fitting correctly and having to relocate the fill neck.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | My replacement gas tank came from Jim Carter, and fit perfectly. I think the 55.1 used a top outlet (different outlet/sending unit) instead of bottom outlet, but that would work with a plug. I investigated cleaning and sealing my tank as it was (I thought) mildly rusted inside. But I wasn't happy with the cost of the materials to clean and reseal it, and was leery of getting that right. It turned out the original tank had a significant rust hole in it as I was cleaning up unused parts.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2010 Posts: 2,315 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,315 | I would try some citric acid mixed with water or vinegar to eat the remaining rust then flush out with hot water and see what it looks like and decide from there. | | | | | Joined: Dec 2020 Posts: 1,964 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,964 | I had good luck using a dog collar link chain. Bust up the rust.
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Oct 2021 Posts: 6,820 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,820 | I've used the Eastwood sloshing compound on two occasions to seal up cleaned out gas tanks. It worked very well in both tanks. The coating started disintegrating after about 20-25 years and I replaced both tanks with new reproductions.
What kind of truck are you working on? The AD tanks available today are built in Canada and are very high quality and less expensive than paying to have the tank boiled out and sealed.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2005 Posts: 1,649 'Bolter | | 'Bolter Joined: Feb 2005 Posts: 1,649 | Lots of videos on YouTube showing different methods to clean out your old gas tank.
~ John in Utah 1946 1/2Ton w/4-speed manual transmission w/1960 235 engineHere We GoFollow in his DITY Bay- If you think about it, it has been one year ago today!
| | | | | Joined: Sep 2025 Posts: 106 'Bolter | | 'Bolter Joined: Sep 2025 Posts: 106 | A couple packs of B.B.'s in the tank, with a bit of gas or something less volatile. Slosh around. 1/4" nuts or something a little smaller works well too. The sharp edges on the nuts knock loose crusty stuff. Use a magnet to make sure you pull all of them out. I've made a sling set up from ratchet straps to suspend the tank. Gives lots of mobility for rocking it around. It beats having to get helper to assist. | | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | Jerry has talked about strapping the tank to a tractor wheel and driving around a while. But not everyone has a tractor.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | A couple of shovels full of pea gravel and my tractor- - - - -bungee cord the tank to a rear wheel and bush hog the pasture! LOL! Jerry
