1 members (UtahYork), 128 guests, and 4 robots.
Topics128,186
Posts1,057,318
Members48,469
This was in a box of miscellaneous parts when I purchased my project. (1940 cab, '37-'39 bed, 1947 chassis)
It has a 5/16" thread.
It looks like something that "When you need it, you need it!"
Nick
1940 KC Model 1/2 Ton Pickup Project
(with '37-'39 Bed and what we think is a '42-'46 Frame)
Taos, New Mexico
back yard wrench turner
Possibly the pivot bolt for the vent in front of the windshield?
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Hi Nick, Somebody else found a similar one of those recently. Yours is a hex, the other one was slotted. Maybe a variation?
Here's the link.
https://www.stovebolt.com/ubbthread...87131/anyone-recognize-these#Post1587131
1950 Chevrolet 3100 (Ol' Roy)
The part I have is similar, but not the same. It may have the same/similar application though.
This one is 1 1/8" long overall and has a 1/2" hex head.
Nick
Taos, New Mexico
If it's oily, it's likely the bolt that holds the oil pump in place. It would have a jam nut on it as well. Here's a pic of a 235 I was tearing down. The 216 has the same retaining bolt (2nd Pic.)
I'd say Kevin has this one pegged. Here's a screen shot from a Chevy Master Parts Book showing the exploded view of the earlier oil pump with the retaining bolt and associated hardware. Good catch Kevin! thumbs_up
~ Dan
1951 Chevy 3 window 3100
Great! I will label it as such so that we don't have to figure it out again.
Thanks!
Nick
Taos, New Mexico
The tip looks too long and the wrong shape for the oil pump retainer bolt.
Well, shucks! I thought we had it nailed. I could post more photos if it would help.
Nick
Taos, New Mexico
I may have a spare I can measure. I'll look in the morning.
Don't have an extra. Sorry. It went away with the engine, apparently.
I'm pretty sure that it is the oil pump retaining screw, contrary to what Carl says. I think the tip shape doesn't matter, It just depends on the diameter of the pin where it goes into the blind hole in the oil pump. If someone has an engine that's partially torn down they could measure to confirm.
The oil pump setscrew has a bigger thread, 7/16, I believe, and the tip has a taper, not a stepped down round tip. The jam nut has a 5/8" wrench size.
Do you have one to confirm that Jerry? My recollection is that the hex head was a 1/2", which would indicate a 5/16" thread. The jam nut is larger, I'm recalling 9/16" hex. And I do think that the tip is stepped down to match the blind hole in the oil pump.
Professional procrastinator
It looks very similar to a couple of bolts that hold the plate down on the top shifting 3 speed trans. The small extension goes down into a rod in the trans. I have a spare trans I can pull the bolts out tonight and compare.
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
Yes, I have several engines in various stages of disassembly. I will take a few pictures, along with thread diameter and pitch measurements in the daylight tomorrow.
1/2" head, 5/16 coarse thread, goes in the two forward holes of the 3 speed top shifter plate. It may fit others as well but I do not know.
Rich, are you just saying it threads into the shifter plate? Did it come from the oil pump bracket? I don't know of any other bolt that has the pin end.
It goes through the top plate into the trans. The tight group of 4 bolts (1 is missing) in the center mount the gear shift.
It's in my 1929-51 parts book...
Group 4.312...Gear Shifter Shaft and Yoke Lock Screw...1940-47...ALL COMM (3-speed)...shaft lock (5/16-18 x 15/16 to end)...p/n 590863...2 required.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks for identifying it!
I am going to make a note of the group and part numbers and put it in a plastic bag with the part in case I ever need it!
Nick
Taos, New Mexico
Moderated by  klhansen, Rusty Rod
