8 members (78buckshot, 2-Ton, Gdads51, Wheelie, Deegs53, Peggy M, Gray_Ghost, 1 invisible), 150 guests, and 3 robots.
Topics128,078
Posts1,056,024
Members48,433
#1598847 03/02/2026 5:13 AM
Looking for any suggestions how I can measure stock frames to check if it’s bent. It’s 3/4” taller front and back on passenger side. I have mustang 2 front and 4 link on back. Currently have truck on jack stands at the rear at same height and front jacks are both set at same height. Currently not running to drive to frame shop. Hope this is the right forum for this question.
Are the jack stands under the frame or the axles. If the latter, it's probably the springs that are the issue.
The 1948-51 Shop Manual (which also covers the years 1952-53) provides guidance for doing frame checks and measurements. They are on Page 2-1 and Page 2-2, with the measurement points and dimensions in the diagram and chart on the second page.
Need to be sure if using the "plumb bob" measuring method that your floor is level so your measurements aren't thrown off because of high or low spots in the floor.
~ Dan
1951 Chevy 3 window 3100
Jack stands are on all four corners of the frame with the wheels off the ground about 1 1/2 inches. Would it be best to put the jack stands under all four corners of the cab and leave the ends of the frame floating?
No, jack stands under the corners of the frame would be the way to go if you're checking the frame. Like Dan said, you may need to check the floor for level. Or you could shim the jack stands so that the corners of the frame are level using a laser level, and then use that laser level as your vertical reference point. Something like THIS
