8 members (Phak1, 68ironhead, Bill Hanlon, Peggy M, 3B, Oswald, elhippie64, 1 invisible),
145
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,834 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | Ordered some new rubber ones. The piece is shaped like a “P”. I see the channels on the two door pieces where the seals go.
The question - how does the rubber piece sit in the channel?
My guess - the leg of the P goes in the channel with the top of the P facing down.
Any confirmation or correction appreciated. Thanks!! | | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | That is the window wiper piece, goes between the door and glass to keep water out of the door. The round section goes in the door channel, the flat section sets horizontal towards the glass, it should wipe the glass as you roll the window up and down. The small lip on the flat section faces up to channel water towards the ends where it runs into the doors anyway. | | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | Thanks so much. My way couldn’t have been more wrong. Appreciate you. | | |
