| | | Forums66 Topics128,212 Posts1,057,463 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2015 Posts: 11 'Bolter | | 'Bolter Joined: Apr 2015 Posts: 11 | I have sold my granny 4 speed in my '63 Chevy long bed truck. Ive been attempting to put a S 10 T5 in. The granny had a yoke bolted to the trans, on the T5 the yoke is a slip yoke. My problem is i had the 2 pc drive shaft shortened in the front by 11.25 inches or so. The new carrier bearing is same as old one. But with the slip yoke i cant put the carrier bearing in the crossmember with the splines for rear shaft being too long to squeeze in from front
Any ideas? I ground the rivets off the bearing support but the hole in crossmember is to small to put in from rear?
Schetk
| | | | | Joined: Sep 2009 Posts: 6,052 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,052 | Can you post pictures of the setup? I think I'm grasping what you are asking about, but seeing would help in trying to come up with a helpful solution.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
