4 members (38Kiwi, UtahYork, dt235sd, Hotrod Lincoln), 123 guests, and 2 robots.
Topics128,196
Posts1,057,390
Members48,471
I have sold my granny 4 speed in my '63 Chevy long bed truck. Ive been attempting to put a S 10 T5 in. The granny had a yoke bolted to the trans, on the T5 the yoke is a slip yoke.
My problem is i had the 2 pc drive shaft shortened in the front by 11.25 inches or so. The new carrier bearing is same as old one. But with the slip yoke i cant put the carrier bearing in the crossmember with the splines for rear shaft being too long to squeeze in from front
Any ideas? I ground the rivets off the bearing support but the hole in crossmember is to small to put in from rear?
Schetk
Can you post pictures of the setup? I think I'm grasping what you are asking about, but seeing would help in trying to come up with a helpful solution.
~ Dan
1951 Chevy 3 window 3100
