3 members (klhansen, Bill Hanlon, Charles in CA), 115 guests, and 1 robot.
Topics128,195
Posts1,057,371
Members48,469
Anyone ever post too much? I hope I don’t 😳
Another issue, my brake pedal gets loose a drops making it an issue!
I’ve tightened it up a few times but it’s loose again.
Is there maybe a special washer I can put on it.
Also the clutch pedal scraped the hole on the floorboard??
1953 Chevy 153A 3/4-ton
Working on my project since 2015
Follow along in my DITY
The joint between the brake pedal and the pivot arm should have serrations that help keep it in position. Also, the bolt needs to be TIGHT. Try some locktite as well as a new lock washer.
The clutch pedal scraping on the hole in the floorboard is a sign that the cab supports are collapsing. Something needs to be shored up or repaired.
Thanks, I just did that on the Px side !
Another common issue with the peddles scraping the floor is a worn out bushing and or peddle shaft .You can usually tell when you put your foot on one of the peddles and wobbles before moving the brake or clutch rods
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
