3 members (Steveoreno, Gdads51, GrandpasJimmy), 132 guests, and 2 robots.
Topics128,191
Posts1,057,362
Members48,469
Moderated
Moderated
I have purchased a 1959 Apache 3100 that is mounted on a 1972 Chevy C-10 frame. My question is if you have done this mod, what radiator did you use and if you have a part number for it that would be helpful? It has the 1959 core support but has a mounting bracket for the frame that makes it unable to put in a '59 radiator ('59 radiator is to tall now due to the frame mounting bracket).
Any help or advice would be appreciated. The truck has a 350 crate motor with a 400 transmission. I will run an electric fan so there will be no fan or shroud required.
Last edited by Gdads51; 02/21/2026 5:37 PM. Reason: editted title to support thread move to the best on topic forum
The EZ-Chassis Swap setup says it uses the original radiator.
Can you give us a couple pictures of your setup?
If you have the 59 core support, that limits your available width for a radiator.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
