0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2026 Posts: 1 Moderated | | Moderated Joined: Feb 2026 Posts: 1 | I have purchased a 1959 Apache 3100 that is mounted on a 1972 Chevy C-10 frame. My question is if you have done this mod, what radiator did you use and if you have a part number for it that would be helpful? It has the 1959 core support but has a mounting bracket for the frame that makes it unable to put in a '59 radiator ('59 radiator is to tall now due to the frame mounting bracket). Any help or advice would be appreciated. The truck has a 350 crate motor with a 400 transmission. I will run an electric fan so there will be no fan or shroud required.
Last edited by Gdads51; 02/21/2026 5:37 PM. Reason: editted title to support thread move to the best on topic forum
| | | | | Joined: Jan 2019 Posts: 2,243 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,243 | The EZ-Chassis Swap setup says it uses the original radiator. Can you give us a couple pictures of your setup? If you have the 59 core support, that limits your available width for a radiator. | | |
