Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (Cletus1950, TUTS 59, Wayne67vert, SmalltownTRKGuy, Otto Skorzeny, UnclePaddy), 146 guests, and 3 robots.
Topics128,281
Posts1,058,462
Members48,490
I just removed the vent glass to put the vent latch on. I’ve managed to hold on to this part for many years thinking I could just put it in😳.
Now I realize that my new latch does not have the pin with it.
I guess I have to buy the entire part again with the pin??
1953 Chevy 153A 3/4-ton
Working on my project since 2015
Follow along in my DITY
You should be able to find a pin at a hardware store, or maybe adapt a nail. It's nothing special. But if you don't want to go that way, I'm pretty sure I have a pin from an original vent latch. PM me your address and I can mail it to you.
O Online: Content
What holds it in?
1950 Chevrolet 3100 (Ol' Roy)
what holds the pin in ? Friction
O Online: Content
So it has to be a pretty tight fit, then.
The originals had a knurled section at the end, so that kept them in place. An easy fit till the last 1/16" or so then tight. I dropped one in the mail to him, but didn't take a picture of it.
A roll pin would work just as well. I believe that's what suppliers furnish with replacement latches.
My son is building a semi automatic rifle much like the M16. I helped him get a pin out of the carry section. He never got it in completely with a press. He bought another pin & with much effort we got it in fully.
I didn’t remove the entire vent from the door so hopefully I can get the pin in. By the way, I don’t have a rubber seal for the actual glass. I plan the use rubber gasket maker. I didn’t bend the frame so it should be a tight fit. Does that sound doable?thank you Hansen!
Glenn, Fixing the seal on the vent windows really should be done by completely rebuilding. Replacing the seal around the frame requires complete disassembly. But sealing around the glass with gasket maker or windshield sealant should work. The glass seal is a tape stuff Link but requires removing the glass from the frame.
Here's a couple excellent how-to videos.
www.youtube.com/watch?v=z6o2KEETyxY&t=144s
www.youtube.com/watch?v=1xEZFaa_ivY&t=128s
You should have no trouble installing the latch and pin with the vent window in place.
I have watched those videos!
I'm an idiot! I thought he was talking about the pin that holds the latch on. But he's actually missing the shaft that the latch goes on. I think he'll need a complete glass frame, as that's either welded or crimped on to the frame.
Here's his pic with the missing shaft highlighted. Maybe someone else (who is smarter than me dang) can help him out and send him a replacement passenger side vent glass frame. Nothing available in the aftermarket that I know of.
Kevin - Don't beat yourself up. I didn't see that either - duh! not me
I actually have an extra entire vent window assembly, but can't recall off the top of my head if it's the passenger or drivers side. headscratch
I'll have to check tomorrow and will report back. If I don't have the right one, Glenn can certainly post an ad in the Truck Parts Wanted forum to see what folks may be able to do to help him out.
~ Dan
1951 Chevy 3 window 3100
I had an extra pair of vent window assemblies, but tossed the ones that were too rusty to use. If I'd held on to them, I could salvaged that shaft. frown
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
@Guitplayer, Glenn doesn't need the pin that holds the locking lever on the shaft, but the shaft that the locking lever pivots on. I made that mistake initially.
