The more I get into the wiring, the more I second guess myself. Can someone tell me the correct way to wire the floor dimmer switch? Please see attached picture with numbered terminals. Not sure which is power in. I think I can see which is high beam.
~ John in Utah 1946 1/2Ton w/4-speed manual transmission w/1960 235 engine Here We Go Follow in his DITY Bay
Your #3 is power in. The other two don't matter which is which, as it just toggles back and forth between #1 and #2.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
Thanks Kevin! I tried to research before any steps, do the steps to install, feel good about it, then later question if I did it correctly. Wiring is not my cup of tea.
