| | | Forums66 Topics128,077 Posts1,056,019 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | the motor was machined and rebuilt stock 500 miles ago recently lost some power. inspection revealed two bent push rods, one on #5, one on #6. two new push rods from napa were almost half inch longer than the old ones. what should the push rod length be for a 54 235? thanks rolf
1963 c10 | | | | | Joined: Feb 2019 Posts: 4,479 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,479 | Your issue sounds like a classic case of old gasoline varnishing up the valves causing them to stick. Did you clean out the gas tank and lines before adding new gas? Better check to see if the affected valves are not stuck or sticking before replacing the pushrods.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 |
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
