1 members (ndkid275), 50 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1598098 02/18/2026 1:25 PM
the motor was machined and rebuilt stock 500 miles ago
recently lost some power.
inspection revealed two bent push rods, one on #5, one on #6.
two new push rods from napa were almost half inch longer than the old ones.
what should the push rod length be for a 54 235?
thanks
rolf
1963 c10
AD Addict & Tinkerer
Your issue sounds like a classic case of old gasoline varnishing up the valves causing them to stick. Did you clean out the gas tank and lines before adding new gas? Better check to see if the affected valves are not stuck or sticking before replacing the pushrods.
Phil
Project Journals
Stovebolt Gallery Forum
Insomniac
Insomniac
Gord 🇨🇦
1954 1/2 ton 235 4 speed
