6 members (Wally / Montana, Gdads51, papas52, TUTS 59, Southerntruck, Jon G), 69 guests, and 3 robots.
Topics128,083
Posts1,056,332
Members48,442
back yard wrench turner
I just reinstalled my Zenith carb back on my truck after having it off for 3 years. It will not idle down. Runs really fast probable 2500 rpms.
I did not try to rebuild it. I did adjust the float to 1 1/2 inches.
Where do I start to get it to idle and run correctly?
the motor is a '55 GMC 270, the carb is the factory one.
carb tag
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
I assume that turning the mixture screw in and out has no effect? Ditto the throttle screw?
1950 Chevrolet 3100 (Ol' Roy)
Disconnect choke, manual throttle and gas pedal throttle linkages.
Does it still idle really fast?
If no, fix your linkage problem(s).
If yes, can you manually pull the carb's throttle lever back to idle?
J Online: Content
Check for vacuum leaks
1951 3100
Carburetion specialist
Either the answer given by Bill or the one by JW51 should find the issue.
Jon
The Carburetor Shop
Does it have a PCV valve, and is it attached/working correctly?
Thank you gentlemen!
It was a combination of 2 issues.
The gasket under the carb spacer was leaking and the linkage rod connecting to the carb was too long.
A new gasket, adjust the linkage rod and it runs awesome.
Wayne
1989 Silverado
J Online: Content
Vac leaks are sneaky. There have been times I’ve thought….”ain’t no way that gasket is leaking enough to matter”
….and been wrong.
1951 3100
