5 members (Philipj, klhansen, 37 GC, Ponchogl, Shade Baby), 133 guests, and 2 robots.
Topics128,143
Posts1,056,786
Members48,454
I posted a request for a flywheel for a GMC 270 in the parts wanted section. However, I have found over many years that they are hard to find.
Has anyone found a flywheel for another engine that will work for a GMC 270?
Thanks!
1950 GMC 100 Panel Truck, 1958 270,
3-spd Saginaw with BW OD,
3.73 12 Bolt Differential from a 1966 C10,
Front Disc Brakes
Hill Holder
Bought it in pieces 9-1976, driving since 6-1978
Follow in the DITY
Since a 216/235/261 bellhousing will bolt onto a GMC engine, and the starters will interchange, it might be possible to redrilll a Chevy flywheel to fit the GMC crankshaft bolt pattern. Is your crankshaft the 4 bolt or 6 bolt type? I have both types of flywheel on hand (Chevy and GMC). I can make some comparison measurements if you like.
Please recheck your post, or pm me.
If you're just looking for a stock flywheel, one from a WWII era military truck should be easy enough to find. p/n 2135482 (flywheel & ring gear assy.)
Not sure if the later 270's used the same flywheel or not.
https://lwdparts.com/product/flywheel-used/
https://www.greenbarnparts.co.uk/product-page/flywheel-take-off-w-nos-ring-gear-fitted
https://jeepest.com/en/engine-cckw353-352/795-flywheel-with-ring-gmc.html
Robert's 270 is a late model which has a 6 bolt flywheel.
My truck had a 235 in it when I bought it in 1976. I found and installed the 270 around 1979. I could not find a flywheel then, so I had the 6 bolt pattern machined into the 4 bolt 235's flywheel. My flywheel is still installed, so I am not 100% confident of my measurement of the bolt circle diameter, but I believe it to be 4-1/16". It is a 168 tooth ring gear.
Front Disc Brakes
Hill Holder
Follow in the DITY
