8 members (Nick in Manitou, GMCJammer51, 68ironhead, Ridgeback, 66flea, 3B, KEVINSKI, 1 invisible), 99 guests, and 2 robots.
Topics128,169
Posts1,057,033
Members48,458
U
U Offline
Hi Guys! I have my rear bumper mounted and was looking for some advice. I originally had my tail light wiring going through a hole in the frame using a rubber grommet, but the bumper bracket covers the hole, so I removed wiring and grommet, installed the bumper and ran the wiring between the bed and frame. I guess it would work OK, but I'm thinking about cutting the mounting bracket (or maybe drilling a hole) to have access to the wiring hole. The bumper bracket is 3/8" metal (pretty beefy), but I don't want to cut it if it will cause issues down the road. Please see attached pictures. Thanks for any input.
~ John in Utah
Here We Go
Follow in his DITY Bay
JMO, but I'd leave the wiring routed over the frame instead of messing with the bumper brackets. I don't think it would cause any issues with the brackets, but it's not worth the effort just to reroute the wiring.
K Online: Content
Looks good the way you have it with the wire loom 2nd the leave it be.I don’t know if my 54 has a hole in the frame near the bumper bracket but my wiring goes the route the same as you have done between the frame and the bed.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
I’m with Kevin.
I think trying to cut out large sections as marked may also reduce the bracket/bumper/tow hitch stability and strength.
Drilling a hole would mean when you need to remove the bumper, that would mean disturbing/disassembling the taillight wiring.
~ Dan
1951 Chevy 3 window 3100
I was going to say the same thing Kevin said. Install a plastic wire loom or that stretchy Chinese Finger puzzle kind and leave it where it is.
1950 Chevrolet 3100 (Ol' Roy)
U
U Offline
Thanks for your input guys. I think I'll leave it alone since I have the bumper installed already. Why create more work for myself.
~ John in Utah
Here We Go
That's pretty much my philosophy for everything.
