2 members (dwreills, Otto Skorzeny), 79 guests, and 2 robots.
Topics128,035
Posts1,055,447
Members48,422
#1596892 01/31/2026 8:41 PM
I had some work done to the head on my chevy 235 and when I put it back on, I got a coolant leak coming from the second to last bolt on the driver side. I thought my head gasket was bad, but then I thought the threads may be going through the water passages. Is my hunch right, and if so, which bolts need thread sealant? I can I just take them out one at a time add sealant an retorque?
Mike
Mike Bell #1596893 01/31/2026 9:38 PM
O Online: Content
Some of the bolts do go through the water jacket. I would remove the head and start over using sealant on all the bolts. Better safe than sorry.
Doing it Onesey -Twosey risks warping the head since it won't be torqued in the proper sequence. You also don't know if water has gotten under the head gasket. Do it right.
1950 Chevrolet 3100 (Ol' Roy)
Mike Bell #1596895 01/31/2026 10:36 PM
The head won't warp if you remove that one bolt and reinstall it. If you remove the head, you'll need a new head gasket. If it's not seeping around the gasket, it's likely that doing one bolt will be OK.
FYI, the shop manual calls for removing two head bolts and replacing with lifting eyes for removing and installing the engine, so GM approves of removing at least two head bolts. They should all be retorqued when you're done.
Mike Bell #1596899 01/31/2026 11:24 PM
Some of the bolts allow oil to come up to lubricate the rocker arm assembly, I assume putting thread sealant on the threads will not mess that up because the oil comes up the bolt after the threads start. Is that correct?
Mike
Mike Bell #1596901 01/31/2026 11:43 PM
Just one bolt is drilled for oil passage, and only on some 235's. It would be the one closest to the rocker oiler assembly. And no, putting thread sealant won't prevent oil from getting thru it.
Mike Bell #1596902 01/31/2026 11:54 PM
Thanks for the help everyone, I will let yall know how it turns out!
Mike
Mike Bell #1596934 02/01/2026 4:42 PM
If you decide to use thread sealant, drain the cooling system low enough that the level is below the head bolts. The one bolt with the oil hole in it will be identified by a slot across the head of the bolt, and it fits the center bolt hole on the passenger's side of the block.
Mike Bell #1596949 02/01/2026 5:59 PM
FYI, 216’s and 235’s head bolts do not go into the water jacket.
Use oil on the threads, not sealer.
My Blog
Mike Bell #1596980 02/02/2026 1:57 AM
Well, I have an embarrassing update. The problem was not the head at all; I just forgot to tighten the water temp sending unit. It just looked like it was coming from the head. Live and learn.
Mike
Mike Bell #1596982 02/02/2026 2:02 AM
Mike - At least it was a relatively easy find and correction. Thanks for coming back and letting us know. thumbs_up
~ Dan
1951 Chevy 3 window 3100
