4 members (52Carl, Gdads51, JW51, Bisbee), 40 guests, and 3 robots.
Topics128,062
Posts1,055,845
Members48,428
#1596882 01/31/2026 6:13 PM
Any one know of a good source for a shortened water pump for a 62 235
Do it yourself- - - - -all it takes is a ruler and a hydraulic press. Push the fan hub back and cut the shaft off to leave a stub to center the pulley.
Like Jerry said, that's what I did a while back when I needed a short water pump. Easy to do, but measure well.
You may want to use the adapter plate to use the older style water pump that will fit your truck like the 216 ..years ago I moved my rad forward because I could as mine is a gmc and it did not require to cut anything up just had to drill new holes for the rad on the opposite side of the cradle. This worked well but the truck would start to overheat if standing in traffic in the summer .Now it does get hot in Northern Ontario but not for long but I see you are in Florida and you may have problems.My truck is a 54 and I see yours is the older style so there may be no issue with yours but with mine the adapter plate puts the fan back to the center of the rad ,now I have not had my truck on the road after I changed mine but what I have read is this is a better fix . Kevin
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
I currently have a shortened water pump, but it's making some noise when cold, but is quiet once warmed up, (it's almost 20 years old). I can reuse the after market pulley, but I'm concerned about pressing through the bearing inside the pump when pressing the on the hub. Doesn't the pump need to be disassembled first?
If you want to have your pump rebuilt, contact one of these companies:
Water pump rebuilder and seller of antique water pumps for all makes and models
Flying Dutchman
Wade Jenezon, 650 Upper River Rd
Gold Hill, OR 97525 USA
1-888-595-1110 Outside the U.S., 1-541-450-227
www.water-pump-rebuilders.com/
Then and Now Automotive
447 Washington St
Weymouth, Ma 02188
Ph: 781.335.8860
Fax: 781.335.1925
https://www.thenandnowautomotive.com/auto-parts-store
The Fryin' Dutchman rebuilt mine for $119
Last edited by Gdads51; 02/18/2026 2:53 AM. Reason: fix then and now auto to new web address
1950 Chevrolet 3100 (Ol' Roy)
Make sure you support the bottom of the shaft when pressing. It's easier than you would think.
The impeller and the engine end of the shaft are exposed on the low mount water pump, so there's no strain on the bearing and seal at all while you're pressing the flange back.
I put that water pump on about 19 or so years ago. It's little wonder I forgot the impeller sticks out the back, I can't even remember yesterday! Thanks guys
