4 members (Southerntruck, Gray_Ghost, Guitplayer, Joe H), 186 guests, and 0 robots.
Topics128,192
Posts1,057,351
Members48,469
I was looking for 1951 chevy truck striker nut plate missing 1 in my truck.
It's the small plate 1 3/8" long 1/2" high 1/4 " thick with 2 tapped holes.
It's what you screw in to to secure the striker plate.
Anyone know were you buy this item.
Thanks John
As far as I know, those aren't reproduced. It would be fairly easy to drill and tap a piece of flat plate, but putting the serrations on it that keep it from shifting around would be a bit harder. Maybe some nicks with a sharp chisel to upset some metal would serve the same purpose as the serrations.
But I'm sure if you post in Truck Parts Wanted in the Swap Meet, a fellow Bolter could come up with one for you.
AD Addict & Tinkerer
That partictular piece is the nut for two 1/4” bolts on top and another for the two on the bottom. The plate(s) with the serrations is sandwiched between the striker plate and the “B” pillar.
One of our members “KCmongo” has a business that specializes in AD parts. He may be able to hook you up. He’s located in KC but he ships.
Here is his contact info: (816) 265-1462
https://mongosgarage.com/
Phil
Project Journals
Stovebolt Gallery Forum
Thanks for the info will contact him see if he has a part.
Use a thin cutoff blade on a small angle grinder or a Dremel tool to put the grooves in the plate. Use the original item you have as a pattern. Easy fix!
Anyone have a pic?
Craig
Originally Posted by cmayna
Anyone have a pic?
I happen to have a pic of the nut plate. This one had a bolt broken off in it and needed to have that removed and the threads chased.
Here's the other side of them.
