2 members (KEVINSKI, 55shaker),
125
Mod | | | Forums66 Topics128,187 Posts1,057,313 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2026 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2026 Posts: 14 | Since I have a Dana S110 sitting around, originally acquired with the idea of putting in my 54 6500 (abandoned the idea) I’ve compared the two some and have been thinking…
The axle shafts in them are not the same at all. Not in length, diameter, spline count or hub mount. The Timken has according to what I’ve read 1 11/16 diameter axle shafts. Not sure if they are equal lengths on each side but they are probably around 34in long. The timken and Dana S110 have very similar pumpkin sizes. The bolt pattern however is different, but maybe the Timken housing could be redrilled for the Dana s110 pumpkin? The S110 has 37, or 40in axle shafts, and is 1.70 roughly in diameter. So basically my wild idea is… would it be possible to combine the two with some custom axle shafts that would fit in the Timken original hubs on one end and hook into the S110 gears on the other?
Interested to hear what people think who know more about this subject than I do.
| | | | | Joined: May 2015 Posts: 11,176 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,176 | There are places that could fabricate custom axles to fit whatever you need. The only rub would be if the splined end is bigger than the hub end. You'd need full specs on each axle.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2010 Posts: 607 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 607 | The Eaton two speed 17221 rear axle was available on a variety of Chevy C60 sized trucks for many years. From what I can tell, it takes the RS404 ring and pinion. Available in any ratio you'd like and brand new for $340 all day long, those cheap gears make me wish I had the Eaton axle under this rig versus the T170 which is more difficult to get parts for it.
| | | | | Joined: Jan 2026 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2026 Posts: 14 | Turns out it’s actually a Timken not an Eaton. I think it’s an E300 | | |
