Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Dakota Bob, John Clawson), 151 guests, and 5 robots.
Topics128,283
Posts1,058,505
Members48,490
I have to make up an intake for my donor engine intake. At the throttle housing it is 4" od but at the mass airflow sensor it is about 3.6 inches in diameter. Will silicone tube's shrink down to make up that much difference with a hose clamp of course.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
I would use a 3.5" to 4" coupler.
ebay
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Silicone tubing won't shrink much, however there are a near infinite number of sizes and adapters and clamps. Sketch out what you need and then hit up the turbo modder stuff on eBay. That's what I did to adapt the tractor radiator into this bus, as it had IIRC a 2.5" bottom outlet and the Cadi water pump is 1 1/2" or so. In my case, I used the stock DeVille lower hose, and simply put the radiator end onto the coolant pump. Had to cut it and install a pipe segment in order to get the 90 degree twist to the right angle. All the contortions actually wound around the oil pump like a factory fit, it looks perfect! Then I used an exhaust pipe size adapter segment along with the silicone hoses for the rest of the size reduction. So everything clears, has lots of room, and allows plenty of flex for movement of engine and frame/radiator.
I think I spent about $45 in total, including stainless steel clamp bands, so it wasn't super expensive. Well, some of the steel clamp bands turned out to not have stainless steel threaded portions :-( But they do work and clamp nice and tight. I added a few pics from back then, to illustrate.
