5 members (Phak1, k2handyman, Hanks custodian, Wheelie, 32Fordpuchoptop), 94 guests, and 2 robots.
Topics128,042
Posts1,055,519
Members48,424
#159636 07/06/2007 5:29 AM
Their has been a lot of talk about air compressor on here but I have a question. I run my AC for at least an hour a day not continuous but usually 20 minutes at a time. I took a temperature reading off the heads with my temperature laser pointer reader thing and it shows their running 300 degrees. Is this normal operating temperature?
38 original
48 panel
59 stepside
46 in the back forty
#159637 07/06/2007 2:12 PM
When you compress air it gets real hot, & the head is the hottest spot. I'm not sure what the normal temps are tho & no way to check mine, sorry. I have a small fan on mine cause its kinda in a corner.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#159638 07/06/2007 2:36 PM
Ex Hall Monitor
Ex Hall Monitor
T Online: Content
Ditto 64Fleetside, I don't know the exact operating temp but the heads will get pretty hot when operating. If you look closly, the pully that turns the crank connected to the pistons is shaped like a fan to help push air across the cylinders to aid in cooling.
#159639 07/08/2007 4:49 AM
I took a reading with my [known accurate] laser temp gauge of this ol dog just after it shut off from a fill - 190° was the hot spot just where the head meets the cooling fins up top [rusty stripe]
#159640 07/08/2007 3:55 PM
Ex Hall Monitor
Ex Hall Monitor
T Online: Content
You've owned that one since the civil war haven't you Bill? grin grin
Moderated by  MNSmith
