| | | Forums66 Topics128,035 Posts1,055,446 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | Their has been a lot of talk about air compressor on here but I have a question. I run my AC for at least an hour a day not continuous but usually 20 minutes at a time. I took a temperature reading off the heads with my temperature laser pointer reader thing and it shows their running 300 degrees. Is this normal operating temperature?
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | When you compress air it gets real hot, & the head is the hottest spot. I'm not sure what the normal temps are tho & no way to check mine, sorry. I have a small fan on mine cause its kinda in a corner. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Ditto 64Fleetside, I don't know the exact operating temp but the heads will get pretty hot when operating. If you look closly, the pully that turns the crank connected to the pistons is shaped like a fan to help push air across the cylinders to aid in cooling.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I took a reading with my [known accurate] laser temp gauge of this ol dog just after it shut off from a fill - 190° was the hot spot just where the head meets the cooling fins up top [rusty stripe] Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You've owned that one since the civil war haven't you Bill?
