Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (1954gmc9314, Hotrod Lincoln, cmayna, ndkid275, latroca52), 199 guests, and 3 robots.
Topics128,292
Posts1,058,590
Members48,492
My project came with incorrect manifolds and carburetor, so I have been collecting bits and pieces to eventually make this thing go.
The intake manifold I am now planning to use came with a gasket between the phenolic spacer and the manifold itself.
I would guess that there should also be a gasket between the phenolic spacer and the carburetor base...but I almost think I read somewhere that there should not.
I have tried to find an illustration of the assembly: manifold, gaskets, spacer, carburetor - but have not found one so far.
Should there be two fiber washers gaskets in that stack?
Do the pieces in the photo look to be correct? (I would replace the fiber washer gasket that was between the manifold and the spacer with a new one.)
Thanks!
Last edited by Nick in Manitou; 01/19/2026 5:23 PM. Reason: correct washer to read gasket
Nick
1940 KC Model 1/2 Ton Pickup Project
(with '37-'39 Bed and what we think is a '42-'46 Frame)
Taos, New Mexico
7
7 Offline
Yes, a gasket should be used on each surface. Any imperfection in the manifold, spacer, and/or carburetor surface needs to be sealed completely, those soft gaskets are designed to prevent vacuum leaks.
Insomniac
Insomniac
I don't have a gasket between the carb and spacer. I know some have chosen to put one there; if you do, make sure that you do not block the vacuum port for the power valve.
Fibre washers? I don't have any.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Gord,
My error. I said fiber washer...but I should have said, "fiber gasket". Sorry for the confusion!
Nick
Taos, New Mexico
Also you may find that by adding that gasket you’ll need to ensure you have sufficient threads of the retention studs.
