0 members (),
118
Mod | | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2021 Posts: 20 TomStenger533600 | | TomStenger533600 Joined: Jan 2021 Posts: 20 | The much earlier posts re: 3600 Steering and front end were helpful in trying to narrow down and resolve my issue without "overkill" .. Drove my grandkids down our long drive during the holidays at maybe 5 mph. Turning the steering wheel to get out of the garage and navigate our drive was a bear. I need to renew my old LA Fitness membership🤗. The steering box can be purchased and replaced by myself probably, but I wonder if binding elsewhere could also cause the issue. King pins, tie rod? At my age I may want to have a local garage that takes in classics look at the front end if the issue goes beyond the box. Thanks for any feedback :^)
TJSting120273600
| | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | Tom, my 3600 was hard to steer when I first started driving it. What I did, fill the steering box with gasoline, let it set for a couple days, then worked the steering wheel back forth and then pulled a lower bolt out, letting the old grease/gas drain. I actually did this little exercise a couple time. Then I filled it with this. I did eventually rebuild the tierod ends, drag link and king pins. After all that it drives almost like it has power steering if you're moving at all. The steering sector flush and fill with 00 grease was an improvement, the rest was icing on the cake. added in edit, be sure the tires have max air pressure recommended. Jack the front up and turn the wheels from lock to lock, checking for any binding, be sure to grease everything. Good Luck RR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 |
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | First thing to do is jack up the axle and support it on both sides with jack stands, with the tires a few inches off the ground. If the steering system is set up right, you should be able to spin the steering wheel lock to lock with just a couple of fingers. If not, start looking for tight spots one at a time- - - -king pins, drag link, tie rods, etc. You should also be able to grab either front tire and turn the wheels lock to lock with very little effort. Too-wide tires, or wheels with too much offset can also increase steering effort- - - -sometimes dramatically. An imaginary line drawn through the king pin, and another through the vertical centerline of the tires should intersect somewhere near the surface of the road. Wheels that increase the track width must scuff the tires across the road surface, instead of making a pivot point where the rubber meets the road. Jerry
| | | | | Joined: Oct 2021 Posts: 6,941 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,941 | The skinnier and taller the tires, the easier it will be to steer and at all speeds assuming all the previously mentioned parts of the steering system are in proper working order.
Without doing anything else to my truck other than installing 16" wheels instead of 15" wheels, and tires with a tread width of about 5" instead of 9" made the truck easy as pie to drive at all speeds. Prior to this it was impossible to steer at low speed and hard to steer at any speed above 10mph.
New shocks made handling perfect.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Apr 2016 Posts: 1,052 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,052 | One bolt to remove the steering arm and you will know if it's in the column/box or front end.
| | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | I use 215/85/R16 tires and love the ability to easily steer at any speed.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jul 2014 Posts: 1,292 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,292 | I also have the 215/85/R16 Tires on my 3604 , it made a huge difference in steering! So much easier to steer at very low to no speed.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Jan 2021 Posts: 20 TomStenger533600 | | TomStenger533600 Joined: Jan 2021 Posts: 20 | Thanks Dusty, RR and everybody for your input and help! I'm sorry for not following the thread after popping the question way back. Finally catching up on everything now and wanted to thank all the folks who responded with very helpful info and advice. And thanks to Dan who moved this to the (proper) Drive line forum. I hope this reply goes out to the thread and that all the guys see it. After a busy year with family etc i 'm finally getting back to the '53. Almost done if I can tackle the door realignment too. Maybe a drive-in sometime in the near future 😁
TJSting120273600
| | | | | Joined: Jul 2014 Posts: 1,292 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,292 | Oh hey, you are very welcome. Looking forward to seeing your finished project.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Jun 2021 Posts: 62 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 62 | My 53 3600 is also hard to steer, I will check out some of these suggestions.
Chris
G.O.T. (Good Ol' Truck), 1953 Chevy 3609 AD 3/4 ton with original 216 c.i. engine, 4 speed transmission, stake bed
| | | | | Joined: Sep 2009 Posts: 5,997 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,997 | Tom - I'll 2nd Dusty's comment "Looking forward to seeing your finished project." Ya gotta post some pictures man, otherwise how can we share and appreciate that great big grin you're sporting!
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
