0 members (), 170 guests, and 7 robots.
Topics128,078
Posts1,056,035
Members48,433
#15960 04/26/2004 7:41 PM
Junior Member
Junior Member
My 1938 1/2 ton has a leaky steering box. Not quite sure where the leak is coming from, but when I fill the box with 160 weight, I get a nice puddle on the floor after a few days. The steering feels pretty tight, so my question is whether or not I can re-seal the steering box without doing a total overhaul. Can I just pull out the box and replace the shaft seal (I'm assuming that's what's leaking) ? Thanks
Alex
Anonymous
Unregistered
Anonymous
Unregistered
Use grease instead of oil - a lot of these old steering boxes leak and it isn't worth the effort to try to get them sealed up unless you are willing to invest copius amounts of time and money with the risk of it still leaking when you are done.
Junior Member
Junior Member
Thanks, Ken. Do you just squirt it full of suspension grease ?
Alex
#15963 04/26/2004 10:21 PM
Anonymous
Unregistered
Anonymous
Unregistered
I would use lithium based wheel bearing grease.
160W is too light. Try Penrite steering box lube from RSC - http://www.restorationstuff.com
Jim
Jim
Junior Member
Junior Member
Thanks, Ken. I think you saved me a bunch of work and $$.
Alex
Junior Member
Junior Member
Thanks for the tim, Jim. Is the Penrite Steering Box lube liquid or solid ?
ALex
My box had a small leak too. I packed it full of grease too. It now works fine.
