5 members (Hotrod Lincoln, Southerntruck, frogfarmer, 3B, Nick in Manitou), 141 guests, and 3 robots.
Topics128,089
Posts1,056,433
Members48,443
#1595782 01/10/2026 10:26 PM
I have two air cleaners for my 54 Canadian gmc and both had no wing nuts on top .I was wondering if anyone knows if there is a special top nut .The pin that comes up for the top to go through has a point on both so they don’t look like they were messed with .The reason I ask this is because there doesn’t seem to be enough to screw a wing nut on as the pin only sticks out about a quarter of a inch .I was thinking of drilling a hole in a 5/16 bolt and threading it so they have more threads to hold down the top.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
My air cleaner has a little knurled nut on it that has a little more reach than a wing nut. It has a narrow part that goes in the hole. Not sure if it's stock, though. It was like that when I got it.
You might replace the threaded rod with a slightly longer one.
1950 Chevrolet 3100 (Ol' Roy)
Yes I think if I make a nut similar to yours we’re it goes through the hole it will have more threads to hold it down thanks for the picture .Kevin
"The Journey"
Follow in the DITY
How about getting a longer piece of threaded rod to replace the short rod ? Kinda like if one wanted to replace their air filter with a thicker one. Odds are they would need a longer center rod.
Craig
Here you go. LINK They also have them with a solid top.
Could do that also but the rod is welded further down but I will take another look to see which is easier. There must have been a similar nut like Otto has on his .
"The Journey"
Follow in the DITY
7
7 Offline
My oil bath unit is original to the truck as far as I can tell, the threaded rod is slightly adjustable at the carburetor bracket and can be unscrewed to allow it to protrude from the top of the air cleaner, a normal wing nut is all that is required for mine.
Thanks Kevin those look like the proper ones that will work
"The Journey"
Follow in the DITY
H Online: Content
I'd suggest using a coupling nut, and grind about a 1/2" long shoulder on it to center the hole in the top. Maybe use a flat washer to spread the load out across a wider area. Then you could either weld/braze a couple of wings onto it, or just use a wrench to tighten it.
www.ebay.com/itm/302491604783?
Ended up getting one from local depot store just had to file a bit so it fits the outer hole . Thanks for the input and suggestions it’s a win.
"The Journey"
Follow in the DITY
Cut your rod off short enough to clear the top after screwing on a coupler. Thread a bit further if you need to. Use a piece of threaded rod to extend the amount you need for your wing nut…
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
