10 members (klhansen, papas52, baldeagle, 1955 1 Series, KEVINSKI, Hotrod Lincoln, TUTS 59, Gdads51, Dusty53, Lonnie), 178 guests, and 3 robots.
Topics128,165
Posts1,056,999
Members48,458
Replacing wheel studs on the rear axles of a ‘46 1/2 ton. Research shows 1/2-20 x 1 63/64? The studs I pulled from the axle are 7/16-20 x 1 1/2. I know that someone, somewhere has been into the rear differential. Did they replace the rear wheel studs with an incorrect size? Appreciate any information.
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
Can’t say for a ‘46 but I can say for sure my ‘37 is 7/16x20 and it hasn’t been messed with except a couple replaced at the machine shop because some PO King Kong snapped them off.
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
Ed - A quick swing through GM Partswiki shows your rear wheel studs should be 7-1/6" - 20 x 1-7/32". The 1/2" - 20 x 1-63/64 ones are listed as 3/4 and 1 ton truck wheels studs.
~ Dan
1951 Chevy 3 window 3100
7/16-20 x 1.75, Moser part # 8259 worked fine on my 1953 3100.
