| | | Forums66 Topics128,021 Posts1,055,354 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | What is an acceptable resistance reading when checking spark plug wires?
1951 3100
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | For RF suppression wires, 1 K-ohm per inch, maximum. For metallic wires, zero. Metallic wires cause premature failure of rotor and distributor cap contacts due to high current flow. Jerry
| | | | | Joined: Mar 2014 Posts: 4,477 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,477 | What type of wire? There are high resistance wires and low resistance wires.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
