1 members (klhansen), 101 guests, and 1 robot.
Topics128,151
Posts1,056,999
Members48,460
Took one front drum off, PLENTY of shoe material left, one adjustment screw was stuck so heated and got it going and adjusted.
Took rear wheels off and got the drums off, not particularly hard, one set of shoes is totally fine, the other the friction material was totally detached from the shoe. Ultimate question is, leave the good side and save the trouble of taking shoes and springs and stuff off, and have one side relined, or take both off and have relined. Drums appear to be in good shape, smooth surface.
Wheel cylinders, springs, etc appear fine.
Not sure how I'll ever get the shoes off with those heavy springs.
1961 Chevy C40 Flatbed 261
On safety of operation systems (lights, brakes, steering, etc.) the very best repair you can do is just barely good enough. That's particularly true on big, heavy rigs. What would an ambulance chasing lawyer do to your future if you happen to have a brake failure and hit a soccer mom's minivan full of kids?
7
7 Offline
I just used a regular brake tool to disassemble mine, similar to your set-up. The brake tool gives you the leverage and hook to slide the springs down the tool.
This is extremely rarely, if ever used on public roads, or over 45 miles per hour, which is why I was considering doing only one side, however, that is a very good point, although the same can be argued about operating old equipment that's considered obsolete to most anyways.
Not really any reason to do one side only anyways, shoe adjustment, maintenance, and replacement, would be stupid to have non synchronized.
More photos of the shoes. To me they look(ed) basically brand new and very servicable.
If the detached lining is still in good shape, you could reattach it with flat head brass machine screws (with self-locking nuts) instead of rivets. Lots of big rig air brake linings were bolted to the brake shoes that way. It's possible the shop that did the reline job just didn't do a good job of riveting the linings on. You could also add some counterbored holes in the lining material between the existing ones and drill a corresponding hole in the brake shoe.
Thanks Jerry!
If the attachment of one brake block failed, I'd be very suspicious of the rest of them. It might be a good idea to replace ALL the rivets with screws, one at a time so you don't lose the alignment of the brake blocks with the shoes. Brass screws won't score the drums, if the linings wear down that far.
I don't know exactly what was used to secure linings to screws on bonded lining brake shoes, but It might be worth investigating. I'm not sure I'd trust screws instead of rivets, as screws can loosen, and don't have the cross section and shear strength that solid section rivets do for the same diameter. Even self-locking nuts can loosen.
I'm surprised that Jerry has recommended the less than original fix on brake systems given his statement above about the best repair being barely good enough.
I'm looking at the different thicknesses of the still attached linings versus the rogue ones. Could something in that brake like a wheel cylinder, be binding up which caused the brake to overheat and shed its lining? Doesn't look burnt, but then again we can't see the drum from the detached side, either. The detached shoe looks pretty shredded, the holes wallowed out too big to reattach.
